tranny blew like a granade
Old Jul 15, 2010 | 08:32 AM
My shop charged me a flat rate of $400 to put in my used transmission, Instead of working hourly we negotiated that nice flat rate since I was "on a budget"
(I love that line )
Old Jul 15, 2010 | 08:53 AM
MAMONTE's Avatar
lol, what? Why would they put a 4t65HD in? You do realize the 4t65HD is virtually no different strength wise than the 4t65 except at the differential- and it sounded like your failure was up at the TC/input shaft area. Not to mention, the 4t65HD from your year would use a different stall torque converter, and would also have lower gearing (2.93 vs 3.29) meaning your car would be noticeably slower than it was before.
I can almost guarantee you that they are NOT putting an HD transmission in it. Simply, they are not going to do something like that as a warranty repair.
Also, in 2006/2007, the gear ratios are different. The 4T65 has several different gear ratios depending on the engine its put with (in fact it always has). The 3.5L gets a 2.86 gear ratio, the 3.9L gets a 3.29 gear ratio, and the 5.3L gets a 3.29 gear ratio.
These are the available ratios for the 4T65:
2.86-Standard Differential only, found with the 3500
3.05-Standard Differential only, found with the 3400
3.29-Standard Differential & HD Differential, found with 3800/3800 SC/3900/5.3L
The Drive and Driven sprocket ratio will directly factor in to calculate the overall transmission ratio. For example most of the Supercharged 3800 powered vehicles come with a 3.29 HD differential but they have a 37/33 sprocket orientation and this will overdrive the transmission and create an overall ratio of 2.93:1
Old Jul 15, 2010 | 07:02 PM
My bad, I was thinking his car was an 04 for some reason; totally forgot about his screen name, lol.
Old Jul 16, 2010 | 12:16 AM
1984SuperSport's Avatar
damn that really sucks.....im glad i have the 5 speed with a 2.8 in my Z24.....just hopin the clutch doesnt go =/
Old Jul 16, 2010 | 04:02 PM
monte07's Avatar
got the car today and it started to over heat like a champ i am about to start a thread on that. but befor the over heat issue it ran like a dream like it did befor the trans falure and replacement.
precious1979
Apr 9, 2013 10:11 PM
Montes4me
Mar 19, 2013 06:10 PM
phoenixdude24
Apr 22, 2010 03:10 PM
zchevroletman91
Feb 18, 2009 05:42 PM
mickey
Jan 29, 2007 10:17 AM
