The tranny finall blew this today :( need advice
Old Mar 17, 2013 | 08:25 PM
Montes4me's Avatar
Default The tranny finall blew this today :( need advice
Well today the trans finally went out. Something shot out of the pan :/. I purchased a used transmission with 40,000 on it for $150 (couldn't pass that kind of deal up). And I am going to have my friend/mechanic help me put it in. Could anybody give me like a complete list of things such as gaskets and stuff I may need? Also a list of problems that I can expect to run into would be fantastic.I have an 02 ls
Old Mar 18, 2013 | 08:39 AM
I can't give you a full list, but this would be a great time to switch over to Dexron 6
Old Mar 18, 2013 | 08:44 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
I can't help, but I wanted to point something out.
Blowing a tranny, means something completely different to the car crowd...
Good luck!
Old Mar 18, 2013 | 09:36 AM
Montes4me's Avatar
Good luck!
Lmao that was pretty funny. I hate that you can't edit the posting title -.-
Old Mar 18, 2013 | 09:37 AM
Sure you can, just post what you want it to say. I'll take that line, make it say that, then delete your post requesting the change
Old Mar 18, 2013 | 09:41 AM
Montes4me's Avatar
I've been between royal purple and dexron 6. Why do you recommend dexron 6?
Old Mar 18, 2013 | 09:44 AM
Because it's GM's new fluid, synthetic, runs cooler, breaks down less, and is 100% compatible with cars that require Dex 3.
If you want to run anything else, that's your call. Just don't go back to Dex3 since there is a better alternative with the GM stamp of approval.
Old Mar 18, 2013 | 11:18 AM
Franks 03SS's Avatar
2011 Monte Of The Year
X2
Youll need the fluid, a new filter which most likely will come with a flimsy rubber gasket. The original pan gasket is rusable if it hadnt been changed out yet... It's a rubber and metal gasket. If it were me I'd get a new metal/rubber one anyways Napa sells the filter and original gasket for around $30 IIRC
Old Mar 18, 2013 | 10:59 PM
Montes4me's Avatar
Ok i will take your word for it lol. I really have no knowledge with transmissions so I appreciate your advice. I got the cv shafts out today along with the air filter box and snorkel. Tomorrow my mechanic is gonna help me drop it down.
Old Mar 18, 2013 | 11:25 PM
Montes4me's Avatar
Smile
X2
That's what my mechanic recomended. I already got it today!
