6th Gen ('00-'05): top swap
Old Jul 30, 2013 | 06:28 PM
scmonte's Avatar
Default top swap
hi i have an extra 3800 engine from a 98 grand prix. i want to build it and do a top swap. when i put it in my 2000 monte carlo do i have to retune my computer? or can i run it as it is? thanks
Old Jul 30, 2013 | 07:25 PM
Yes you need to do a full tune for a top-swap.
Most w-body vendors sell PCMs that you would be able to use, although 2000-2002 are a pretty hard year to create a .bin file for. They are custom made and hashed together typically.
Old Jul 31, 2013 | 12:30 PM
scmonte's Avatar
what would happen if i didnt tune it? would a ecm from a gtp work?
Old Jul 31, 2013 | 01:33 PM
The PCM is tied to the VIN so your car wouldn't start.
If you didn't tune it, the car either wouldn't stay running, or it would knock so badly that you would seriously damage it.
Old Jul 31, 2013 | 03:24 PM
scmonte's Avatar
ok thanks.
Old Aug 27, 2013 | 08:25 PM
scmonte's Avatar
will pontiac grand prix gtp headers fit a 2000 n/a 3.8 monte carlo? i looked up the stock exhaust manifold part numbers, and they both are the same.
Old Aug 28, 2013 | 07:08 AM
There COULD be clearance issues with the fans on the Monte.
Old Aug 28, 2013 | 01:47 PM
turbo monte's Avatar
as chibi said you HAVE to tune for a top swap, if you dont you turn your engine into a grenade. the headers will bolt up fine but as he mentioned some had clearance issues with the fans and some didnt.
sickofsoyo
Mar 10, 2009 10:24 PM
sprfrk2005
22
May 22, 2008 01:25 PM
vita
Mar 11, 2008 11:49 AM
1999L36
Dec 15, 2007 10:47 AM
Cowboy6622
Dec 15, 2007 10:40 AM
