99 Monte Carlo 3.1L - Engine/Trans Slip
Old Aug 28, 2013 | 12:15 PM
dez2188's Avatar
Default 99 Monte Carlo 3.1L - Engine/Trans Slip
I put in the STP (red bottle) to save gas and clean out my fuel tank a couple weeks ago. Every since then my car has been slipping when I make left turns. Nothing too crazy. I'm scared that it might be my transmission. The shop just dropped a motor in it 2 months ago and I started driving it 3 weeks ago. People told me it could be that I didn't put in the STP the correct way, which I didn't. I didn't let all my gas burn out before I put it in the tank. I think I need to change the fuel filter. I know for a fact I don't need an oil change because I just got a new oil filter when the motor was dropped in there. Someone told me I may need to replace the transmission mount and that should solve the problem. I'm hearing numerous things. What do you guys think?
Old Aug 28, 2013 | 02:58 PM
Hi `Dez,
Your STP fuel treatment will not affect your transmission. I suggest that you go back to the shop that installed your engine & have them check it out...How many miles are on your trans ? Was the fluid/filter changed on your trans ?
Was it a mechanic that said you needed a new trans mount ?
Please supply as much information as you can about your problem so that our member's can assist/help. > Good Luck
The0neN0nly
Aug 1, 2014 04:55 PM
Jparks
Sep 14, 2013 05:10 PM
Mr.Monte
May 23, 2012 09:06 PM
pushing100
May 16, 2011 05:14 PM
tyler111991
Apr 11, 2011 11:33 AM
