Steering whine
Old 11-21-2010 | 07:35 PM
03SSChevyFun's Avatar
Post Steering whine
my 03 Monte 3.8 doesn't like corners. at least the power steering belt tells me so. whenever i hit even a moderate corner with moderate acceleration while im turning, the steering emits a nasty sounding whine that tends to linger for a few miles afterwards. does anyone know why it does this and if its bad?
Old 11-21-2010 | 07:40 PM
Overdose666's Avatar
Mine had done that for years, and after a few mechanics told me the power steering was fine and these cars are naturally noisy i checked it myself. Power steering fluid was almost empty so i filled it up then left the cap off, started up the car and turned it all the way to the left, then all the way to the right. Repeated that about 12 times. Slapped the power steering cap back on and its been quiet ever since.
Old 11-21-2010 | 08:00 PM
really? thats an interesting kinda "home remedy." ill have to try it after the winter is over. thanks!
Old 11-21-2010 | 08:04 PM
zipper's Avatar
Check the steering rack for leaks and see if your power steering fluid is low. If you top it off and later on the whine comes back then there's a leak somewhere.
Old 11-21-2010 | 08:06 PM
well turning the wheel with the reservoir open just helps get any air bubbles out, im not 100% sure but i think thats how they do it in most shops
Old 11-21-2010 | 08:07 PM
okay, i see. and i just had my car inspected (i live in PA) and then i checked it out myself too. power steering fluid is near full and no leaks anywhere.
Old 11-21-2010 | 08:12 PM
you could try flushing it
TomF106SS
03-16-2015 12:03 PM
07MonteMadness
03-23-2011 10:01 AM
cain45
08-20-2007 09:57 AM
SoCalSS
08-18-2005 01:45 PM
SoCalSS
08-13-2005 05:51 PM
