4t65e-hd swap
Old Nov 21, 2010 | 05:34 PM
Overdose666's Avatar
Default 4t65e-hd swap
The GTP is probably gonna be here tuesday, I'm planning a top swap. Im also considering a tranny swap, other than the passenger side axle what would need to be changed on my monte?
Old Nov 21, 2010 | 07:15 PM
The diff and diff housing also (housing is bigger, hence the need for a different passenger axle).
Old Nov 21, 2010 | 07:34 PM
alrighty anything else?
Old Nov 21, 2010 | 07:52 PM
zipper's Avatar
Just do the Diff w/housing and the passenger side axle. You don't want the whole tranny because the gear ratios are different (2.92 in the GTP and 3.29 in yours). If you swapped the whole tranny you would have to flash the PCM. Plus the non-HD ratios are better for acceleration.
Old Nov 21, 2010 | 08:01 PM
Well im going to be getting a programmer, so the PCM should be a problem. I wasn't aware of the different gear ratios, but thanks for the heads up, we already got alot of work ahead of us, and u just gave us a little less.
ecosta221
15
Apr 18, 2014 06:30 PM
stillonly1
Jul 5, 2011 02:35 PM
nemesis
Jan 15, 2009 11:00 PM
mrl390
May 31, 2008 11:48 AM
88ss408
Jan 9, 2008 12:33 PM
