fuel rail leak
Old Jan 24, 2011 | 09:02 PM
augi's Avatar
Default fuel rail leak
Alright, I have been battling this problem for a while. My rear fuel rail has a leak right where the line plugs into it. I have replaced the coupler and o- ring and its still leaking. Is there another o- ring inside there? If so, how do I replace it? Anyone have any input whatsoever?
Old Jan 24, 2011 | 09:08 PM
Budsjlm's Avatar
get a 4th gen!
no seriously tho i know it may not be the most cost effective but have you consided replacing the rail?
i'm not real familiar with the 3.8 any pics of what your talking about?
is this a quick connect?,screw on style?
Old Jan 24, 2011 | 10:04 PM
augi's Avatar
Quick connect, the line just snaps onto the quick connect. Im going to look again in the morning and see if there are any other o rings on there that just may need replacing. All I can see so far is one...
Old Jan 24, 2011 | 11:01 PM
zipper's Avatar
During what times do you see the leak?
Old Jan 25, 2011 | 07:09 AM
augi's Avatar
When I press or pull on that coupling. The front one doesn't do it at all even when I do so.
Every now and then I see a drop or two coming from it, but when there's pressure on it (engine cover on) it almost pours out
Old Jan 25, 2011 | 10:03 AM
tranquiljoe's Avatar
The quick-connect rails have two o-rings in each line.
Overdose666
Apr 19, 2021 12:10 AM
godfather202
Dec 19, 2014 02:47 PM
LittleE
Apr 3, 2013 11:09 PM
apguy
May 24, 2012 01:46 PM
Shandley
Dec 12, 2011 03:29 PM
