Fuel system leak on 2002 Monte SS
Old May 21, 2012 | 04:15 PM
ang913's Avatar
Default Fuel system leak on 2002 Monte SS
I recenty noticed a big drop in my cars MPG's and im only getting like 250 miles a tank. My check engine light turned on recently too. I had it checked out and its showing a leak in the EVAP system. The mechanic said it can be a loose gas cap or a hole somewhere. Im just trying to get an idea on how much im looking at spending on a repair. Any ideas?
Old May 22, 2012 | 08:06 AM
03SSLE's Avatar
The most common problem is a bad seal on the gas cap. I'd start by replacing it. If the code comes back you'll need to take the car to a shop and have them do a smoke test to determine where the leak is. I have no idea what shop rates are in your area.
BIGAL131
Sep 19, 2022 02:00 PM
MonteSquarlo
Dec 16, 2012 06:18 PM
Christopher Gray
14
Sep 6, 2012 08:08 AM
monte67
May 25, 2012 08:16 PM
William3742
Sep 28, 2009 08:32 PM
