My monte is dead :(
Old Jul 31, 2012 | 09:59 PM
  #211
Franks 03SS's Avatar
2011 Monte Of The Year
Originally Posted by Jomao_o
Woah... Good luck!
I hope it works out and you get to put more miles on your Monte.
Thanks bro
I have used the red scotch brite pad from a kit like this to clean the deck surface of the block where the head sits:
2" Surface Conditioning Kit
But you want to blow out the cylinders and make sure that debris is OUT of the cylinder (helps to shove rags in the ones that you can).
That kit comes in handy for a LOT of stuff!!
Just don't focus on one area, buzz the surface constantly. DO NOT use sand paper (or at least I would not).
Thanks jason, i'll make sure and get that kit tomorrow, difinitely didnt want to use sandpaper lol
Old Jul 31, 2012 | 10:01 PM
  #212
OH and did swap sensors over? Like the MAP sensor? I'm not 100% sure the L26 uses the same sensors the L26 uses. Just a thought, compare them before they are GONE!
all sensors looked identical, connectors and all i didnt check the MAP sensor though i think thats the only one i missed lol
Old Jul 31, 2012 | 10:08 PM
  #213
another question, are the 3 Flywheel bolts that bolt up to the TC TTY bolts??
Old Jul 31, 2012 | 10:44 PM
  #214
turbo monte's Avatar
nope reuse them
Old Aug 1, 2012 | 07:49 AM
  #215
nope reuse them
Thanks man
Old Aug 1, 2012 | 08:10 AM
  #216
Looking good!
If the UIM won't polish the way you want it, it would look pretty nice painted white
Old Aug 1, 2012 | 09:02 AM
  #217
Looking good!
Thanks mike, and if it doesnt turn out nice im thinking a metallic silver
i think it'll look nice with some red that im going to have in there
Old Aug 1, 2012 | 09:05 AM
  #218
damn now that i thought about it, i might just go ahead and paint it it's going to be PITA to polish and very time consuming, but then again polished would look much better
Old Aug 1, 2012 | 10:12 AM
  #219
Budsjlm's Avatar
Just and the sand the crap out of it then clear coat it for that brushed aluminum look, use you're dremal for those harder to reach spots, just make sure to have it going all one way
Old Aug 1, 2012 | 01:24 PM
  #220
i decided not to polish it 2 hours of sanding and it's barely smoothing the surface on it, and i still hadnt got to the hard to reach areas
going to paint it a metallic silver then clear coat it i dont think an engine cover is going on this one :p
didnt get anything done today, had to cut the grass lol and then this rain doesnt help any, its supposed to rain all week. luckily i have my motor in the living room
