My monte is dead :(
Old Jul 25, 2012 | 07:49 PM
  #111
Habbibie's Avatar
Good Luck Frank. Everyone runs into problems their first time so be expecting it and dont take out your rage on the car.
Old Jul 25, 2012 | 08:31 PM
  #112
Originally Posted by monte07
hay frank i wouldent reuse the same head bolts had a bad experence reuseing them but to be honest i am glad you are getting every thing back to gether.
I've re-used head bolts and known others who have also re-used head bolts (one on a Vette that has seen a LOT of track time and abuse). As long as the threads are good, the heads aren't rounded it.s not a problem. My 3100 Grand Am got head bolts re-used at 180K and it's got almost 220K now.
The key is to have a good torque wrench (I do NOT recommend the Harbor Freight torque wrenches) and to torque to the proper spec in the pattern the GM shop book (not a Chiltons or Haynes book) says (the Chilton/Haynes books are great references but are sometimes incorrect in what they say, I would validate torque spec and pattern against the real shop book).
You also want to validate that the mating/decking surface of the heads is flat and not warped. Poor man's way is to run a good straight edge across it.
I won't say NOT to replace the head bolts, I'm just saying I'm not a believer in it being a requirement.
Old Jul 26, 2012 | 07:59 AM
  #113
03SSLE's Avatar
Whether you reuse head bolts or not depends on the engine design. Some engines use what they call torque to yield head bolts. These engines require that you replace the head bolts when you reinstall the head(s). On engines that don't use torque to yield head bolts you are fine reusing the old bolts. Just make sure to clean the threads on the bolt and in the block (also do this for torque to yield) so you get an accurate reading when torquing them.
Old Jul 26, 2012 | 08:59 AM
  #114
Blazed SS's Avatar
IT HERTZ
Haha thanks man
Now that I have to replace my radiator I feel like i have to buy more new parts lol especially when I take apart the L26 :p
Man this is a great time to get rid of the Orange coolant 2 and go back to green because you can Blow everything out . Or that is at least what did
Old Jul 26, 2012 | 09:37 AM
  #115
Franks 03SS's Avatar
2011 Monte Of The Year
Thanks man, and im not mad at my car lol im actually excited to get it running again
Im just going to go ahead and get new bolts whats a set cost like $20ish?
and im also going to be getting a new torque wrench, how bad are the HB ones?
i guess im going to need a 1/4" and a 1/2" wrench lol
yep i was already running green coolant
i just hosed all of the orange stuff out of the L26, it was pretty clean too
Old Jul 26, 2012 | 09:48 AM
  #116
lightly washed some of the crud off, of course the real cleaning will come when i take it apart lol looks like this motor is in pretty good shape
The UIM will definitley be getting polished
here's the little info they had on it
i hope it's not a high mileage motor that will give me problems right away lol
Old Jul 26, 2012 | 10:13 AM
  #117
Blazed SS's Avatar
IT HERTZ
ceramic coat those exhaust manifolds and then you can get that ugly cover off and cut allot of heat mine were sand blasted and done in black for 15$ at a local powder coat shop
we took the cover off after we say how it looked and i just shot mine with some 1100 VHT engine paint to add some color and to make it easier to spot leaks
Old Jul 26, 2012 | 10:14 AM
  #118
monte07's Avatar
it shouldent but i would replace the spark plugs and the lim and uim to make sure there wouldent be a surprise when starting the engine. but i hope you will be happy i am glad that you were able to get a engine for it
Old Jul 26, 2012 | 10:16 AM
  #119
monte07's Avatar
oh i forgot to mention when you post i posted at the same time sorry it looks good from before asnd after picks
Old Jul 26, 2012 | 10:25 AM
  #120
BlackRainSS's Avatar
I doubt you'll have issues with it, but you never know. To me it looks pretty clean but you can't tell miles from that. the important thing is that you got one and that means your Monte will be back on the road again
