Motor is messed up
Old Jun 17, 2011 | 09:57 PM
gremlint3ch's Avatar
Default Motor is messed up
Ok so I think my friend just messed his motor up bad
2001 ss 3.6 v6 auto
He had a water leak engine got hot oil was boiling and he had to add some oil he was really low so he added 5 quits of motor oil will it was hot like a idiot . When he starts to drive the car it is shaking so bad I think he bent something and messed the motor up really bad. He has not started since we went home and we are trying to find out whats wrong with it. I think his cam or piston is bent what do you all think..
Please help
Old Jun 17, 2011 | 10:07 PM
mrl390's Avatar
Pull that motor out and find a used long block to throw in there. I wouldnt even spend the time to tear the old one apart. There are so many things that could potentially be wrong. The bottom end could be bad from running it without oil, he could have hydrolocked the motor by overheating it and blowing a head gasket/intake gasket, he could have rounded a lobe off the cam from running it without oil, ect. For a few hundred bucks you could easily find a used long block and swap the motor out in a weekend.
Old Jun 17, 2011 | 10:17 PM
What all would it take to get a v8 from around the same year and drop it in and how much do you think the parts would be?
Old Jun 18, 2011 | 06:50 AM
Warhorse's Avatar
There was a thread on potential V8 swap into the 6th gen, but I believe the gist of it was, if even possible, needing the whole cradle, possibly suspension in front, the wiring was a biggie, IIRC?! Please do a search, you will then be able to see what was said, I don't remember enough about it, other than I would love to sink a V8 into mine!!
Mike
Old Jun 18, 2011 | 06:56 AM
mrl390's Avatar
There is a write up in the how to section about it I believe. Its far from a "drop in" job.
Old Jun 18, 2011 | 07:09 AM
Warhorse's Avatar
Thanks Matt, for the clarfication, I couldn't remember what section it was in either! I just remembered reading it, and from what was said, not impossible, but well out of the means of just a drop in procedure!!! Intrigueing idea none-the-less, no?!
Mike
Old Jun 18, 2011 | 08:50 AM
Mike 00LS's Avatar
Member Dredd put the LS4 engine in his 2001 SS. Here's his thread on it; https://montecarloforum.com/forum/si...per-ls4-26283/
Old Jun 18, 2011 | 04:38 PM
Fist the '00-'05 Montes never had a v8 to my knowledge. So I'm sure the swap is a BIG undertaking. Looking at the thread mogwog posted, it apparently will fit and can be done.
Second, I do agree, when the car was ran on that low a level of oil to the point it is believed the oil was boiling, consider the engine toast. If the oil was boiling all the metal, bearings, gaskets and seals where heated beyond their acceptable thresholds and probably suffered a LOT of friction abuse due to lack of oil.
Old Jun 19, 2011 | 01:28 AM
nitehawkjcb's Avatar
2001 ss 3.6 v6 auto
Please help
3.6 you say.... ha
If it was 5 qts low on oil, that motor is finished. These cars only hold 4.5-5 quarts.
nlewis44
Dec 15, 2010 07:57 PM
S_DAHM
Aug 19, 2010 09:47 AM
monte07
Dec 4, 2009 12:09 PM
DCfla
Sep 3, 2009 04:36 PM
04MonteLS
Jul 30, 2005 12:18 PM
