I messed up!! Please help!!
Old Aug 16, 2009 | 06:55 PM
DCfla's Avatar
Default I messed up!! Please help!!
Alright everyone, so if you had seen my pictures after using VHT spray, my tail lights did not come out to well.
Well today I decided to just finish off the bottle of it that I had, and they were looking so good and shiny, because I guess last time I just did not do a thick enough coat of it, and while it was drying, I had a little left in the bottle, so i thought "hey i might as well just finish off the bottle." well, big mistake.
It started dripping, and looked bad.
So i went to the store and bought a new bottle of the VHT nite shade, and also 2000 grit sandpaper,
So in the morning when i know its completely dry, i am planning on sanding it down and re-spraying it.
Is this the best idea to do to fix it or what?
Please help, any info would be great.
Old Aug 16, 2009 | 08:03 PM
Enzo354's Avatar
STILL SLOW
sand it to the red, or its going to be very uneven. Pic up some clear while your at it.
Old Aug 16, 2009 | 08:09 PM
DCfla's Avatar
So sand the old VHT all the way off?
And i do have some clear coat, i used that last time after i sprayed on the VHT, but now i found out the VHT already has clear coat mixed into it.
Old Aug 17, 2009 | 12:15 AM
Enzo354's Avatar
STILL SLOW
Well unless your very careful sanding at night youll be able to see dim spots and bright spots on the lights when its coming through. And if you think the vht will handle its own without clear i guess its all just opinion.
Old Aug 17, 2009 | 12:38 AM
DCfla's Avatar
So if i just sand odd the vht back to the red and redo completely i wont have dim spots?
i only have about 5 sheets of the 2000 grit paper, should i do it wet or not?
Old Aug 17, 2009 | 12:44 AM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
with grit paper you always want to use it constantly wet, always keep the grit paper wet when using it
Old Aug 17, 2009 | 09:34 AM
1FastMonteCarloLT's Avatar
I used the VHT and to be honest I'd go for the clear coat b/c I did one tail with it and one without and with it it looks more shiny imo
Old Aug 17, 2009 | 11:24 AM
DCfla's Avatar
well i just tried to do it.. couldnt even sand it all the way down and their just ruined.. so im just giving up on it. so the monte will sit at the house from now on until i come up with money to buy new plain red ones or ones that are already black LED lights.. great.
anyone know anywhere cheap to get tail lights?
Old Sep 3, 2009 | 04:36 PM
put some more on to just make it look decent, completely rediculous to just not drive it
87montecarlo
Dec 9, 2013 04:20 PM
nlewis44
Dec 15, 2010 07:57 PM
monte07
Dec 4, 2009 12:09 PM
04MonteLS
Jul 30, 2005 12:18 PM
