6th Gen ('00-'05): jack is down again please help
Old Jan 15, 2014 | 06:10 PM
Looks like the oil sending unit to me also...
Over my lifetime I have experienced many a sending unit failing just like yours... In the pic you can also see where it hits the block when its leaking under pressure(the clean area) and the oil build up adjacent to it on the hoses...
That should definitely resolve the oil leak thru the sending unit...
Also you have to remember... That unit is with in the galley of the oil pump which is a high pressure area thus leaving the "clean" spot on the block..
Old Jan 15, 2014 | 07:48 PM
owens91's Avatar
If I don't ha e the roght socket can a monkey wrench possibly do?
Old Jan 15, 2014 | 07:52 PM
turbo monte's Avatar
this is why i said its hard to get to lol. i dont know of any socket deep enough to fit it, i use a adjustable "cresent" wrench
Old Jan 15, 2014 | 11:46 PM
owens91's Avatar
ok here is an update, first i want to say thank you to all the memberes who put their imput at such a fast speed. times like this i am glad to be a member of this forum. i believe i made this thread around 3 something today, needed help to identify this part and now at 12:16 i am in the house and Jack is back up and running. i got home around 10 haha and ya i did have to use ma monkey wrench...could of went faster if i had the right socket. but here is some before and after vids/pics
the replacement part is a duralast from autozone
again people thanks for all the help is all is well tomorrow when i check again this will be a case closed
Old Jan 15, 2014 | 11:51 PM
owens91's Avatar
forgot to add the bad sending unit....it shot out much worse earlier guessing casue the car was hot when i first seen it
Old Jan 16, 2014 | 05:27 AM
Nice video, that thing was a gusher!!!
Old Jan 16, 2014 | 06:40 AM
Holy Crap!
I had n idea it was that bad...(insert shock and aww and a holy beejesus here) Why pardner I think you struck earl!!!!!
I'm glad that we were able to help/remedy that gusher!
To think you were driving around with it like that... How long was it leaking like that? before you were able to fix it? it must have cost you a small fortune in replacement oil for sure....
Sheew, I think I would have rigged some sorta catch can in the mean time!
At least the underside of your Monte is well lubricated...LOL
Thanks for shareing !!!
Glad its a non issue now for You!
Old Jan 16, 2014 | 07:33 AM
Glad to see you got it fixed!
Now when you do an oil change, don't pick up another Fram oil filter
Old Jan 16, 2014 | 09:51 AM
owens91's Avatar
Ya had to get some 7-11 oil, then I had ma girl bring me a gallon of autozone oil. I drove like tht for around 10 miles. And the engine started to tick. I was scared to death. Dont tick anymore. Crazy thing is I had 500 miles till ma next oil change glad to say dropped ma friend off this morning and still no leaks. This is officially case closed!...and hey mike what's wrong with fram they cool haha
Old Jan 16, 2014 | 10:19 AM
I always found them to be cheaply built.
If you are buying oil filters on a budget, take a look at Purolator ones, they seem to keep a nice metal core.
