Installing Power Steering Pump - any tips??
Old Jul 27, 2012 | 06:25 PM
SS02's Avatar
Exclamation Installing Power Steering Pump - any tips??
tackling a ps pump change 2002 ss in the morning.
Saw a couple of real good posts on here, but I am just looking for any pearls of wisdom before I start. any issues or tips?
Do I really have to remove the passenger side tire?
I have the puller/ the pump and some Lucas ps fluid.
thanks everyone
Old Jul 27, 2012 | 06:45 PM
I have not changed a PS pump, but I have changed the high pressure line. To get to the fittings for the lines, I got to them from removing the passenger side wheel. If you had other access to pull the pump elsewhere on the car, it might make a difference, but I am a skeptic.
Are you sure it's the pump that's bad??? I assume you're leaking fluid. If so, it's probably a pine, not the pump.
Also, a day before you start, might not hurt to hit all bolts and fittings with PB Blaster. Might also be worth considering replacing the lines while you are messing with it.
Old Jul 28, 2012 | 10:37 AM
SS02's Avatar
no leaks
It is whiney like it is low on fluid, but the level is spot on /fluid looks okay.
When the car is stopped and you turn the wheel, you get the whine. Also now getting the whine while accelerating , without steering input.
And I might go get the lines while I have it all apart. I am gonna price them real quick.
Thanks for the input.
Old Jul 28, 2012 | 10:45 AM
You may want to replace the belts too since you'll already have them off. If they need replacing that is.
Old Jul 28, 2012 | 12:19 PM
SS02's Avatar
I didnt see one, but is there a power steering fluid filter?
autozone site shows one but it looks like an add on.
Old Jul 28, 2012 | 12:21 PM
SS02's Avatar
good idea - it looks okay but for 25 bucks I am going to replace
Old Jul 28, 2012 | 11:53 PM
I'm not aware of a "power steering filter". But your problem sounds like a whining pump in deed.
When you get your belt, might I suggest a Goodyear Gatorback belt?? Supposed to be some of the best belts you can pop on. I bought mine brand new in the sleeve for less then $30 from a guy on eBay (Buy It Now auction).
Old Jul 29, 2012 | 02:23 AM
+1 on the gatorback belts. I bought a timing belt for another vehicle and it was way better quality then the OEM one.
Old Jul 29, 2012 | 01:34 PM
SS02's Avatar
Thanks everyone for the tips !
New pump is in and purrs like a kitten.
Replaced belt (GB) and went ahead and flushed radiator while I was under the hood.
Took about two hours but went smooth.
Thanks for the input. I am going to post some new pictures to My Garage
JoeD
Apr 2, 2014 06:49 AM
2003supersport
Oct 30, 2008 10:32 PM
24_48Fan
Jan 13, 2007 07:49 PM
Gr4v3_7
Dec 6, 2006 05:34 PM
