Fuel pump not getting any power
Old Mar 31, 2014 | 09:00 AM
JoeD's Avatar
Awaiting Email Confirmation
Default Fuel pump not getting any power
Hello I replaced my fuel pump because I thought it was bad come to find out I not getting any power to it at all I changed the fuses relays an still nothing at all what could I look for or to get power back to it again go have a 04 Monte Carlo
Old Apr 1, 2014 | 11:57 AM
JoeD's Avatar
Nobody knows anything?
Old Apr 1, 2014 | 12:16 PM
dbaldwin's Avatar
Check if the relay is getting power to it. If the keyed/switching side isn't it could be a bad ignition switch. If the constant (switched/pump power suple) side isn't then trace the wire back checking for voltage drop.
Old Apr 2, 2014 | 06:49 AM
03SSLE's Avatar
A common problem on a lot of GM vehicles is the connector that plugs into the pigtail on the pump. It gets saturated with water and road debris which creates a bad connection. Another place to check is the ground wire.
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
03SSLE
Dec 29, 2012 09:41 AM
SS02
Jul 29, 2012 01:34 PM
mr202monte
Oct 31, 2010 02:09 PM
