Power steering pump
Old Nov 25, 2006 | 10:13 PM
Gr4v3_7's Avatar
Default Power steering pump
Hey, I have a problem I think is the power steering pump low on fluid. Where is the reservoir for the power steering pump (reservoir) so I can check the fluid and add some if needed?? I looked under the hood and could not find anything. Thanks.
Old Nov 27, 2006 | 10:08 PM
Gr4v3_7's Avatar
Default RE: Power steering pump
Anyone???
Old Nov 27, 2006 | 10:30 PM
DESS03's Avatar
look at the rear of the motor behund the altenator and down you will see it its kinda hidden and hard to get to
Old Nov 28, 2006 | 01:18 AM
2000_BLACK_SS's Avatar
since we are talking abou power steering i have started to notice latley that when ever i hit a corner hard or turn alot i start to get a type of buzz when i turn the steering wheel and it becomes harder to turn anybody know what the problem is?
Old Nov 28, 2006 | 08:28 PM
04 Intimidator's Avatar
Not knowing what the buzz really sounds like and it's location, it could be a total lack of power steering fluid or an air bubble in the system though it is highly unlikely. Have you checked your fluid yet? Where can you tell where the buzz is coming from?
Old Nov 28, 2006 | 10:44 PM
Sounds like the sound is coming from the left side when sitting in the car
Old Dec 3, 2006 | 01:03 AM
djizzle's Avatar
check to see if anything is hiitn ur tires first...second check ur levels...i think it has a red cap...if its low fill it and turn the wheell a few times and check again....
Old Dec 5, 2006 | 03:12 AM
Sciggy's Avatar
Depending on your driving habits, it could be the power steering motor itself. If you turn the wheel to lock every time you make a sharp turn, it puts a lot of strain on the mechanism. If you do it every once in a while its not a big deal, if it happens frequently it could cause a problem later on down the line.
Steve
Old Dec 5, 2006 | 09:30 AM
ORIGINAL: djizzle
X2. Look for any kind of wear, but check the fluid levels and we'll go from there.
Old Dec 6, 2006 | 05:34 PM
cain45's Avatar
I have a brand new OEM GM pump with reservoir if you need one.
suburbiangiant
Dec 24, 2013 01:17 AM
mperko86
Apr 9, 2012 11:04 PM
2003supersport
Oct 30, 2008 10:32 PM
24_48Fan
Jan 13, 2007 07:49 PM
