hei ignition
You are installing an HEI Distributor????
Well just connect the red power wire to the right side of the cap and the Brown Tach Wire to the left side of the cap. The Red power wire is on a connector with a white wire, i believe, just cut the red wire off and use a female connector to connect it to the distributor. There is no need for the white wire... Use manifold vacuum for the vacuum advance, and make sure your on top dead center. I can get pics of what you need to do if you get stuck...
sure, ill take some pics, if u want u can email me at johnierotten@pennswoods.net, thanks
Cobramen
May 25, 2005 01:06 PM
