Gen V Upgrade With I/C and Hood Clearance??
Old Dec 4, 2013 | 03:01 PM
Hunter1's Avatar
Default Gen V Upgrade With I/C and Hood Clearance??
Hello all,
I am new to the forum and to this point have been learning a lot from all the folks out there. Many Thanks!
I am hoping for some advice or information perhaps from someone that has done the upgrade I am contemplating.
I have an 04 Supercharged SS. I am looking to swap the Gen 3 for a Gen V supercharger however would also like to install a full sized intercooler below the Gen V. My question to the experts is.....Will this all fit under the hood? I believe things are tight under there with a Gen 3 and an I/C.....will it all fit with a Gen V?
Thanks in advance for those that may have some advice to share.
Old Dec 5, 2013 | 03:04 AM
turbo monte's Avatar
I'm almost certain it will fit no problem, they make spacers that go I between the car body and sub frame for a little extra clearance if you need it as well.
Old Dec 5, 2013 | 05:22 AM
Hunter1's Avatar
Thanks for the reply Turbo. I just want to put in the research before I start installing. The Gen V is substantially larger than the Gen 3 AND the I/C core is quite the "height adder" so am seeking advice from others. I'm thinking there must be someone out there that's done the same.
Thanks again
Old Dec 5, 2013 | 08:29 AM
I'm sure there is. I know it can be done on the grand prix and Bonneville with no issues so I'm almost certain there won't be any issue on the Monte either.
deeboe
Mar 15, 2010 09:13 PM
TheMonteCarloKid
Feb 6, 2010 04:11 PM
joemccall86
Dec 12, 2007 04:45 PM
scc24540
Dec 1, 2007 06:28 PM
jaws7647
Oct 26, 2007 09:04 PM
