Fuel injector cleaner
Old 10-25-2012 | 11:50 PM
trvsglr's Avatar
Is it ok to just put Seafoam right in your gas tank? And if it is when should i do it? Right before filling or after? Thanks!
Old 10-26-2012 | 09:25 AM
According to the bottle. Run the car down to at least 1/4 tank of gas, add the whole bottle to your gas tank, THEN fill up completely. Also drive that tank of gas a little harder than usual and let it get down to almost empty before filling up (so you aren't diluting any further)
Old 10-26-2012 | 01:14 PM
Mike 00LS's Avatar
SeaFoam can go right in the tank, yes. Follow the directions that Chibi gave in the post above.
Only suggestion I'd make is to use a product called Chevron Techron. Mike mentioned it on the previous page of the thread. It's actually endorsed and sold by GM as a fuel cleaner, Chevron is just the name used for it when it's sold in stores. It cleans, but also has a lube in it for the fuel pump.
I've started using Chevron in my gas tank (every 3-4 months) and then once a year (in the Spring) I run half a can of Seafoam through my crank case and the other half through the engine.
bigdomvegas
03-02-2010 01:50 PM
joesumrall
06-18-2008 09:33 PM
Shasta
11-28-2007 09:29 PM
wiz kidd
06-16-2007 11:43 PM
batman
04-23-2006 10:35 PM
Quick Reply: Fuel injector cleaner
