6th Gen ('00-'05): Is this double roller usable?
Old Dec 1, 2014 | 02:24 PM
Dstevens's Avatar
Default Is this double roller usable?
Bought this off a guy on the forum. is it still usable or do you think some of the teeth are a little to scored for the chain to stay on?
Old Dec 1, 2014 | 02:25 PM
Dstevens's Avatar
Old Dec 1, 2014 | 05:54 PM
Me personally...
I'd say no...
I see way to much wear/damage to even consider it.
I'm sure this is not what you wanted hear...
Maybe someone else will chime in with other ideas or opinions.
Old Dec 1, 2014 | 08:37 PM
Dstevens's Avatar
I kinda figured so. ill let him know that he needs to be more detailed in the condition of the product. I got a pic before he sent it but I could not see all this until it got here
Old Dec 2, 2014 | 08:57 PM
I don't see a point in even bothering with a used setup anyways. A whole new setup is only $200, and it's cheap insurance for something that could seriously destroy your engine if it went bad.
Same with used single valvesprings...
Old Dec 4, 2014 | 11:32 PM
turbo monte's Avatar
Don't use that in an engine. It's only use is a paper weight. Never use a jp timing set either as many people have had major failures with them. Only timing set I'll ever use is a roll master
Old Dec 5, 2014 | 06:17 PM
owens91's Avatar
IMO never use anything used for an engine
Old Dec 7, 2014 | 12:05 AM
I would have to disagree on that. There are some used items that I wouldn't worry about buying used at all - a cam for example on a hydraulic roller lifter car (assuming they aren't pulling it because something broke that caused piston to valve contact).
Also, items that don't really wear out or move are good to buy used also - headers, throttle body, intake, etc.
Old Dec 7, 2014 | 09:35 PM
owens91's Avatar
i see where you are coming from so i would rephrase, on my car which i care about dearly i wouldnt use used parts for the engine, i want to make last for ever
Old Dec 7, 2014 | 11:49 PM
I've used many used parts and have had great luck with them. There are some parts I would never buy used as well though.
JoeD
Jul 21, 2014 11:57 PM
wottreng33
Feb 10, 2010 09:26 PM
silver1
Sep 3, 2009 03:46 PM
ExplosiveSoundz
Apr 22, 2008 08:02 AM
