window roller upper button
Old Aug 15, 2009 | 01:17 PM
silver1's Avatar
Default window roller upper button
ok, what could it be. my passenger window rolls down but wont roll up. BUT i can do both from diver side. any suggestions?
Old Aug 15, 2009 | 02:10 PM
...Bad passenger side switch, or it got corroded or dirty contacts.
Moisture from water/condensation can affect the switch. Good Luck...Check back 2 see what our expert tech members posts/suggest.
Old Aug 15, 2009 | 02:42 PM
2000_BLACK_SS's Avatar
Bad switch on the passenger side is what i would guess.
I had a similiar problem on my drivers side and a new switch fixed it.
Old Aug 15, 2009 | 05:59 PM
Enzo354's Avatar
STILL SLOW
Same problem i have, I took it apart and put it back together, now it works but the light in it is out. lol
Old Aug 19, 2009 | 12:17 AM
silver1's Avatar
thanks folks. i will attempt to repair it and report back
Old Aug 19, 2009 | 12:31 AM
Pure2sin's Avatar
I had a similar issue but my window wouldnt go up or down. I bought a switch from here:
http://www.gmpartsdirect.com/catalog/frameset.cfm
-Choose make and model and year.
-Choose "Door" then chose "interior trim" and to the right you will see window switch.
-Should be around $12 for the switch NEW.
Works fine now.
Old Aug 21, 2009 | 01:01 AM
silver1's Avatar
sweet. thanks
Old Sep 3, 2009 | 03:40 PM
ATP03SS's Avatar
Pure2sin, i have the same problem. but its on the drivers side and driversside window. so on the website would i need the left side or right side switch?
Old Sep 3, 2009 | 03:46 PM
Pure2sin's Avatar
You would need the more expensive one. The Left side. It is more because its all one unit.
wottreng33
Feb 10, 2010 09:26 PM
enibum
Nov 26, 2008 07:55 PM
ExplosiveSoundz
Apr 22, 2008 08:02 AM
