double roller question
Old Jul 21, 2014 | 06:47 PM
JoeD's Avatar
Awaiting Email Confirmation
Default double roller question
just wanna make sure it was done right when installing a double roller timing chain i dont need to install the damper which came with the stock timing chain?
Old Jul 21, 2014 | 11:57 PM
turbo monte's Avatar
First off what engine? I'm assuming a 3800. If this is the case no chain tensioner needs to be used. Be sure to get a machined pump cover so the chain doesn't rub and fail. Also it's a good idea to get the gears machined to the block so they fit true and don't stress the chain.
People say double gasket the front cover for clearance, I say it's stupid to do this. Double gasket makes for an easy leaky gasket and I feel it's not enough clearance. This is like a cheap bandaid fix instead of a permanent solution.
Dstevens
Dec 7, 2014 11:49 PM
wottreng33
Feb 10, 2010 09:26 PM
silver1
Sep 3, 2009 03:46 PM
ExplosiveSoundz
Apr 22, 2008 08:02 AM
