Connecting Rods
i will be replacing the pistons on my LQ4 build to increase the compression. My question is should I just replace the conecting rods since it will be apart anyway? I also am not sure if i change them should I go with an I-beam or H-beam.
I guess it depends how high you plan to spin it, may be worthwhile to do stronger rod bolts if you're going to rev the heck out of it.
Opinion Needed: Turbo 3800
hunterh047
Jun 13, 2018 09:51 PM
6th Gen ('00-'05): Heads and cam with turbo upgrade but stock pistons. opinons needed
godfather202
Sep 13, 2014 04:58 PM
