Connecting Rods
i will be replacing the pistons on my LQ4 build to increase the compression. My question is should I just replace the conecting rods since it will be apart anyway? I also am not sure if i change them should I go with an I-beam or H-beam.
Originally Posted by MechMan
(Post 714452)
I guess it depends how high you plan to spin it, may be worthwhile to do stronger rod bolts if you're going to rev the heck out of it. |
Would like to see some pictures of the work, if possible.
