Connecting Rods
Old Oct 11, 2018 | 11:48 AM
MechMan's Avatar
Default Connecting Rods
i will be replacing the pistons on my LQ4 build to increase the compression. My question is should I just replace the conecting rods since it will be apart anyway? I also am not sure if i change them should I go with an I-beam or H-beam.
Old Oct 15, 2018 | 09:18 PM
Since you're upping compression, I take it you're scrapping the boost idea? I wouldn't touch the rods in that case. Plenty of SBE LQs up to 700 whp on boost, so you'll have plenty of headroom.
I guess it depends how high you plan to spin it, may be worthwhile to do stronger rod bolts if you're going to rev the heck out of it.
Old Oct 18, 2018 | 11:51 AM
HKnux5112's Avatar
Would like to see some pictures of the work, if possible.
MechMan
Sep 13, 2018 04:02 PM
hunterh047
Jun 13, 2018 09:51 PM
godfather202
Sep 13, 2014 04:58 PM
jhong292
21
Nov 25, 2008 09:07 PM
oldude
Mar 29, 2007 10:45 PM
