Welding aluminum
Old Mar 28, 2007 | 09:54 PM
oldude's Avatar
Default Welding aluminum
Just found a new prob on my 01. Where the tie rod end goes thru the knuckle (I think that's what it's called) and the nut goes on the threaded shaft. That piece of aluminum is cracked from top to bottom along the tie rod end threads. It's got a gap about an 1/8" wide. Can that be safely welded?
Old Mar 28, 2007 | 10:58 PM
04 Intimidator's Avatar
Default RE: Welding aluminum
It shoud be able to be safely welded, I can't say with any certainty without seeing it. But if your asking that question, don't do it yourself. Welding aluminum is extreamly difficult as it has a tendancy to deform by twisting and expanding. You might weld it only to find out that it won't fit.
So you should either have this professionally welded or better yet, get a new one and replace it. A much less chance of catostrophic failure in the end and a safer ride.
Old Mar 29, 2007 | 12:11 AM
InTheIROC's Avatar
You mean the spindle and tie rod are cracked? I would definitely suggest replacing them if that is the case.
Old Mar 29, 2007 | 12:39 AM
oldude's Avatar
I think that in the interest of safety for my family, and the people that may be around the car if a weld should fail I'm going to trash that whole idea.
Old Mar 29, 2007 | 01:06 PM
oldude's Avatar
Default RE: Welding aluminum UPDATE
I found one at the junk yard for $35.00. I had went to the GM dealer and they wanted $400.00 for a new one.
Old Mar 29, 2007 | 10:45 PM
ORIGINAL: oldude
Sweet Deal!!! And it should be perfectly safe!
2000_BLACK_SS
Mar 27, 2014 05:27 PM
BeachBumMike
Mar 9, 2008 05:37 PM
rcohen
Jul 20, 2007 07:17 AM
87monte
Jan 16, 2007 04:09 AM
cain45
Sep 22, 2006 08:07 PM
