Check engine light / No remote start
Old Jan 13, 2014 | 12:36 PM
Longislandmonte's Avatar
Default Check engine light / No remote start
So I was installing my interior led lights and at first I wired them to the CNSTR fuse an it worked at first! Then when I started the car- check engine light... So I switched it over to the OnStar fuse and it is showing up on the dash. To make it so much better the remote start just clicks once then doesn't start, I was thinking maybe the remote start fuse blew, does anyone know where it is?
Old Jan 13, 2014 | 03:35 PM
Wait this is awkward I figured it out lol thanks anyway!
Old Jan 13, 2014 | 05:50 PM
OK,
So what was the problem?
Care to let us know what the fix is?
It just may help someone else down the road as well..
Old Jan 13, 2014 | 08:38 PM
DaNfRoMSt.PaUl's Avatar
Sounds like you got it. I know from experience that the remote start will not function with a check engine light on. You will have to get any codes cleared unless they cleared themselves. Good luck.
Old Jan 14, 2014 | 11:09 PM
Yeah that's basically what happened in this case, I must have triggered a code while wiring the interior led lights and rewriting the amp in the car, the guy before me drew power from the fuel pump for the amp and something about it just made me feel alittle... Unsafe about the wiring there so I wired the led's to onstar and the amp to the airbag/display. I'm going to take the monte down to my dad's friend's shop so he can clear the code for me so everything's back to working order and I won't have people getting in my car anymore and immediately saying "hey your check engine light is on"
newmonteowner
Jun 4, 2020 01:48 PM
Knightwolf702
May 14, 2014 07:13 PM
Inkedpinkedstarr
Mar 22, 2014 10:11 AM
tatbone
Mar 10, 2011 09:09 PM
poynter32
Feb 10, 2009 10:41 PM
