02 ss wont start, check engine light only...help!
Old Mar 8, 2011 | 12:58 PM
tatbone's Avatar
Default 02 ss wont start, check engine light only...help!
I have an 02 monte ss that will not start. Lights and everything works fine. Battery is practically brand new. when you turn the key to start the car, everything shuts off and the check engine light comes on only. my car only has 55,000 original miles on it. wondering if it is some kind of security issue? any thoughts?
Old Mar 8, 2011 | 01:39 PM
Welcome to the Monte Carlo Family...
Sorry to read about your problem...The first thing I would do is make sure your battery connections are tight & also the connection is tight on your starter. (Even new batteries can have bad cells & not have enough juice to turn over a engine).
Is this the first time this has happened ? Please post as many details as possible on your problem & hopefuly one of our expert tech member's can assist/help..
Keep checking back on your thread to see if any new posts have been made....Good Luck
Old Mar 10, 2011 | 09:09 PM
cityboi202's Avatar
If your security light comes on to i might can help you. turn the key to the on postion. turn your radio off and then hold down disp button 4 til you see display pop up on your radio. go to alarm and turn it off. then turn car off and it should turn right on. i had the same thing happen to my car today.
schoentges16
Feb 27, 2021 06:43 AM
bigdomvegas
Oct 21, 2017 07:54 PM
BrandonStebing
Jul 25, 2014 11:03 AM
Raider
Jun 18, 2014 11:15 PM
Knightwolf702
May 14, 2014 07:13 PM
