Carburetor Help
Old Sep 24, 2008 | 11:56 PM
Racefan67x's Avatar
Default Carburetor Help
I just bought a 1986 Monte Carlo LS with a 305. A previous owner changed the carburetor to a computer controlled QuadraJet, and now the car won't run right to save it's life. I was wondering would there be a problem if I disregarded and, and bypassed all the computer controls and installed a traditional carburetor. Would that be a problem, or should I fix the old carburator.
Old Sep 25, 2008 | 12:45 PM
88ss408's Avatar
Default RE: Carburetor Help
if you bypass you ecu with a older style carb you will need the old style distributor as well the one wil the coil in the cap and vac. advance
but the ccc Q-jet's can work real good if everything is there that is needed to work
MonteFox
Nov 4, 2012 06:52 PM
84MC
May 16, 2011 04:49 AM
Decortez
Mar 24, 2011 08:44 AM
nighthawk626
Jan 18, 2010 04:17 PM
steptoe
Nov 17, 2006 11:00 PM
