ss nose and carburetor installation
Old Jan 16, 2010 | 02:10 PM
nighthawk626's Avatar
Cool ss nose and carburetor installation
1986 monte ss with 350 sbc, edelbrock carb and intake
two questions, or maybe more.
firstly: my first time pulling off a 2bb carb to put in a 4bbl with electric choke. i kno where all the hoses connect but im not 100 percent on how to connect the electric choke.
second. my ss nose has a crack in it, am i screwed and have to go buy a new nose or is there any possible way on earth to fix that up
any help guys
Old Jan 17, 2010 | 08:24 PM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
depends on how bad the crack is and where it's locates. Body shops can plactic weld, but a lot depends on the situation. Best bet, talk to some of the body shops and see what they think.
Old Jan 18, 2010 | 11:50 AM
the_full_monte's Avatar
2bbl? is that on the 350 you put in ? the stock 305 should have had a wire on it for the choke on the q jet
Old Jan 18, 2010 | 01:12 PM
seawolf18's Avatar
For the choke all you need to do if ground the black wire, usually a screw on the body of the carb, and the red wire to a switched power source. A lot of guys tap the hot wire for the HEI, due to it has a full 12 volts of power, and it only has power when the key is on. If you have a 2 bbl manifold, I would suggest switching that out to a 4 bbl one. An edelbrock performer works good for a mild engine, and is not that expensive.
Old Jan 18, 2010 | 04:17 PM
skylark65's Avatar
check out honest charlie's speed shop, and OPGI ( original parts group inc) for the nose
honest charlie's has an SS nose avalible for about $450, which would need to be painted. plus if shipping is not free, thats gonna run ya quite a bit for something so big. but it looks to be a nice peice. see for yourself:
http://store.honestcharley.com/monte...mpers-grilles/
P343
Apr 18, 2024 01:22 PM
84MC
May 16, 2011 04:49 AM
Decortez
Mar 24, 2011 08:44 AM
Racefan67x
Sep 25, 2008 12:45 PM
steptoe
Nov 17, 2006 11:00 PM
