Rochester carburetor troubleshooting
Old May 12, 2011 | 12:59 AM
84MC's Avatar
Default Rochester carburetor troubleshooting
My 84 MC has a start up problem where it idles low, and smokes grey blue. I tried the sea foam today, and it seemed to remedy the problem. However, I noticed that it's almost coming back. I want to know if the computer-controlled carburetor has an automatic choke when the engine is cold. For some reason insufficient air is not burning off the fuel and idling high. What would your recommendations be and where can I find the kits to rebuild if I have to? Or am I better off looking for a refurbished carburetor? I am trying to keep the car as stock as possible.
Old May 14, 2011 | 03:16 AM
finallyss's Avatar
Make sure your Rochester carb is electric Q-Jet, unless you took off the computer. If you stll running computer on your car, make sure the carb and dizzy box are computer compatible.
If you DO have electric Q-jet, it will be more easier you get a reman carb as TPS in these carb are extremely sensitive.
As for the Grey-Blue smoke, it usually oil burning. Keep in mind that if no one did a rebuilt on these motor, these are 26years old motor. Either the valve seal are gone, rings need to be replace, or both.
Old May 15, 2011 | 08:56 PM
84MC's Avatar
The carb is still computer controlled and all the original equipment is still there. I want to keep it all stock but I am having a hard time finding people who can rebuild carbs. Especially these.
Old May 16, 2011 | 04:49 AM
finallyss's Avatar
If you really want to keep this all stock and keep the carb, you have two choice. Buy a reman carb from your local parts shop (which I don't recommend), or send your carb to reputable shop to have it rebuilt.
If you decided to have it rebuilt, just do some google search near your area to have it rebuilt.
Donutboy97
Jun 10, 2014 12:18 PM
mattthias
Mar 7, 2012 07:42 PM
coltonarnold
Oct 18, 2011 07:28 PM
djizzle
Dec 19, 2006 01:38 PM
steptoe
Nov 17, 2006 11:00 PM
