CAI Intake Question
Old Mar 12, 2014 | 03:17 PM
Sajfar's Avatar
Question CAI Intake Question
Just want to start with saying hello to everyone, this is my first post and have recently acquired a 2002 Monte Carlo SS with a v6 3800 Series 2 engine from my late father. I am working on restoring it and building it up for some performance upgrades.
I have recently purchased a Weapon-R CAI it has a place for the PCV hose, but I have not been able to locate this hose anywhere (maybe looking in the wrong location), all I seen was the sensor with the electrical connector attached directly to it on the engine.
Is there anyone that has a setup like this that may provide some assistance.
Thank You in advance.
Old Mar 12, 2014 | 03:26 PM
to the forum!
Do you have any pictures or links to what you bought?
The PCV on these cars is on the passenger side of the engine.
The electrical connector in your stock tube is the IAT (idle air temperature) sensor.
Old Mar 12, 2014 | 03:42 PM
Sajfar's Avatar
Default Link to CAI
Thank You for the reply here is the link to the CAI - http://www.carid.com/2002-chevy-mont...ke-285117.html
Old Mar 12, 2014 | 09:35 PM
owens91's Avatar
are you sure that is for the 3.8 motor? the one hole should only be for the IAT. i dont know if this is for the 3.4 motor the link didnt say too much
Old Mar 13, 2014 | 07:48 AM
Did you open or attempt install yet? Can you still return it?
Can I recommend returning it for either of the following:
1998 - 2004 3.8L Monte Carlo Intake System (Black Powder Coated)
Easy Performance - Wizaired Cold Air Induction System #EP-CAI
ZZPerformance - ZZP 3800 Cold Air Intake #ZZ-3800CAI
What you purchased is just a hot air intake. You want to seal the filter off from the outside air, and the above 3 are some of the best premade kits on the market.
Old Mar 13, 2014 | 04:49 PM
Sajfar's Avatar
it was supposed to be for the 3.8, however it doesn't seem to be. I will contact the manufacturer directly and find out if I have to have them replace it with a different on..
thank you for all the input.
Old Mar 13, 2014 | 09:05 PM
owens91's Avatar
or you could make ya own fenderwell intake cheaper option but that deff didnt seem like the right intake
JAFO
Aug 1, 2015 03:44 PM
deeboe
Apr 12, 2010 11:22 PM
AwesomeSS
Mar 3, 2009 04:05 PM
sonin66
Feb 15, 2009 11:08 PM
