2001 Coolant Sensor Help
Old May 12, 2011 | 11:57 PM
jsamuel01's Avatar
Default 2001 Coolant Sensor Help
Hey guys, I have a 2001 ss and have been having cooling issues (seems like we all do If anyone has ever replaced the coolant sensor, how the heck do I get it out? I keep whacking my wrench on either the exhaust manifold or the motor mount and it is so ticking me off. I just pulled the car seat from the monte and put it in myFord; I am not moving the Chevy until I change out the sensor, so PLEASE HELP!!!
Old May 13, 2011 | 06:14 AM
Check out the below links, until one of our expert tech members post additional infor on your problem...
Good Luck 4-Sure..
How Diagnose The Coolant Sensor On 2001 Chevy Monte Carlo | Pdf ...
Remove the low coolant level sensor. Refer to Coolant Level Module .... Buick Lucerne 2001-2005 Chevrolet Venture 2001-2007 Chevrolet Impala, Monte Carlo ...
pdfrepairmanual.com/.../how+diagnose+the+coolant+sensor+on+2001+chevy +monte+carlo - Cached- Block all pdfrepairmanual.com results
Not helpful? You can block pdfrepairmanual.com results when you're signed in to search.pdfrepairmanual.com
Answers.com - Where is the coolant temperature sensor on a 2001 ...
Just remove your oil cap and then the plastic tube that the cap was screwed onto . Grab ahold of the tube and ... When was the first Chevy Monte Carlo built. Related answers: ... How do you change coolant sensor on a 2001 monte carlo? ...
wiki.answers.com › ... › ChevroletChevy Monte Carlo - Cached - Similar
Old May 13, 2011 | 07:34 AM
7801MonteMan's Avatar
Make sure the engine is cool. I believe you make need to remove the battery for clearance. Once that is done there is a silver clip that has to be reomve from the sensor that keeps it locked into the radiator. Once that is removed you can pull the sensor. Before removing the sensor put a bucket under this area to make sure that when you pull the sensor out it spills out into the bucket.
I know this works for the the LS's I want to say its the same for the SS's.
Old May 13, 2011 | 01:01 PM
jsamuel01's Avatar
OKAY... I know WHERE the sensor is (on the drivers side under the thermostat housing on the 3800, thats 3.8L), and I know what size socket to pull it, I have done this procedure on a different model with no problem, but the 01 monte/impala has all these stupid motor mount locations and impact braces and what-not. The space is too tight to get most thick wrenches into and I cannot get on it with a deep socket because of the angle of the sensor. It is impossible to get on it with regular sockets because of that annoying little plastic piece on the sensor; if I put my wrench on it I can turn it maybe 20 degrees and then my wrench hits the motor mount and I have to pull it off... except I can't without turning the thing back 20 degrees... its like I need a special tool or something...
Old May 13, 2011 | 01:36 PM
Under the Thermostat is the Temperature Sensor isn't it?
The Coolant Sensor is in the radiator
Old May 14, 2011 | 10:40 AM
Sure is...now to figure out which one the OP is looking for.
Old May 16, 2011 | 03:38 PM
jsamuel01's Avatar
Coolant Temperature Sensor... thanks for the help everybody, I fixed it. Had to buy new tools for the job, but I fixed it. On that note, I am an amateur mechanic and since I was getting no temperature input on the dash and a coolant temperature code, I decided that the first thing I should try would be the Coolant temp sensor; I replaced it and still I get no change in temperature even on a hot day when I am driving a lot... so could the t-stat be causing this problem? How can I tell?
tarfin
Nov 21, 2009 01:17 PM
Great White North
May 30, 2008 02:21 PM
SHORTTRACKRACING18
Dec 18, 2007 12:21 AM
lanniec
Dec 15, 2007 10:52 PM
enibum
Feb 25, 2007 12:25 PM
