momentary "wheel slip" right after green light
Old Apr 13, 2011 | 06:34 PM
pushing100's Avatar
Question momentary "wheel slip" right after green light
I'm new to the forum and would really appreciate input on a problem I just started to have after taking off the snows:
Upon normal acceleration from a dead stop (such as when the traffic light turns green), the car begins moving normally for about 1 second, then for a very brief period the car behaves as if the front drive wheels slip, and then acceleration resumes normally. This only happens sporadically (once or twice a week). The tires are not slipping but it behaves the same as if I drove over a small ice patch. The lug nuts are tight. I'm hoping it's not some kind of <gulp> transmission slippage problem...
Thanks guys. It's an '03 SS.
May 11: Where did the Mormon ad come from? It wasn't part of my posting (although I'll probably vote for Romney).
Last edited by pushing100; May 11, 2011 at 03:19 AM. Reason: A Mormon ad appeared out of nowhere that's not mine
Old Apr 13, 2011 | 06:59 PM
mrl390's Avatar
May be time for a fluid and filter change in the transmission, depending on the mileage since it was last serviced. Does sound like slippage to me. Also, check to make sure it has enough fluid.
Old Apr 14, 2011 | 03:57 AM
pushing100's Avatar
Thanks mrl. I'll check the level. (I think the dealer changed the fluid and filter last year but will double-check).
Old Apr 14, 2011 | 08:32 AM
Are the tires TCS activating, or is the car just slamming you?
Old Apr 16, 2011 | 04:36 PM
pushing100's Avatar
dunno for sure. It's only happened 3-4 times (and not at all since I first posted). Plus it's so quick that it's tough to observe much. (I don't even know if the tach jumps up.)
Old May 6, 2011 | 02:03 PM
tapeworm4602's Avatar
I am having a similar issue with my '04 Intimidator ss. Mine seems more frequent, having 106k miles, hard to believe the tranny would be slipping unless the previous owner beat the hell out of it and never changed the fluid/filter. Of course the problem doesn't occur all the time so it's difficult for myself or mechanic to observe any issue.
Old May 10, 2011 | 05:29 PM
pushing100's Avatar
mrl390 was right on the money about checking the transmission fluid level. I had the dealer top it off yesterday and now there's no hesitation or slippage whatsoever!
Thanks again mrl
Old May 10, 2011 | 07:00 PM
If the traction active light comes on it's probably a wheel hub
Old May 16, 2011 | 05:14 PM
Could also be a break issue.. maybe they don't release all the way, one may be holding onto a wheel.
dez2188
Aug 28, 2013 02:58 PM
Mr.Monte
May 23, 2012 09:06 PM
blackmonte781
Sep 14, 2011 08:46 PM
86 luxury sport
Jun 6, 2011 02:41 AM
tyler111991
Apr 11, 2011 11:33 AM
