2000 Monte SS
Old Sep 26, 2012 | 05:57 PM
Jarhead2294's Avatar
Default 2000 Monte SS
I was thinking of swapping out my 3.8 for a 3.4. I just want to know how difficult it would be to do and what are the pros and cons of doing that
Old Sep 26, 2012 | 05:59 PM
01 Monte SS's Avatar
why??
Old Sep 26, 2012 | 06:08 PM
Jomao_o's Avatar
Pulley?
Great if you have the supporting mods.
Bad idea if you don't have the supporting mods.
Old Sep 26, 2012 | 06:09 PM
cause the 3.8 sounds like ****, unless you know of some mods I can do to make it sound better and get rid of the rasp.
Old Sep 26, 2012 | 06:14 PM
Jomao_o's Avatar
Keep the 3.8, much better motor, bigger aftermarket.
Old Sep 26, 2012 | 06:18 PM
k i will keep the 3.8 then, but i just can't stand the raspiness of the motor.
Old Sep 26, 2012 | 06:19 PM
You want to ditch your 3800 because of the sound? I would help you out but that's just ridiculous IMHO. Put some quiet flow mufflers or keep the stock setup if you don't like the rasp.
I have no experience with a 3.4, and very little with a 3.8, but to my knowledge the possibilities for modifying your 3800 go as far as your wallet allows. To eliminate the rasp, boost would help, my 3.8 exhaust sounds way different after I supercharged it.
Old Sep 26, 2012 | 06:24 PM
mairj40's Avatar
Did you remove the resonator and cat? My 3800 in my 2001 is totally stock and it has no rasp at all.
80sselky
May 17, 2011 04:13 AM
Mike
Aug 29, 2006 10:33 PM
te100
Jan 29, 2006 05:31 PM
keghead40
May 27, 2005 12:43 AM
Juve
Dec 1, 2004 12:46 PM
