brakes on 2000 monte ss
Old Dec 1, 2004 | 07:57 AM
Juve's Avatar
Default brakes on 2000 monte ss
greetings
I bought a 2000 ss new, and at 75k miles, had to replace the front and rear brake rotors. Anyone out there have good luck with aftermarket pads? I want some pads that won't wear out the rotors so fast, but don't want any squealing or noise. Was wodering about the 'green stuff' pads and ceramic. Any input would be appreciated
Juve
Old Dec 1, 2004 | 09:54 AM
montejass's Avatar
Default RE: brakes on 2000 monte ss
Hello Juve,
If your rotors lasted 75K your doing well!!!
The only way to curb rotor damage is to keep them cool. I.E. stay away from hard braking/riding the brakes.
If you have already replaced your rotors I've heard nothing but good things about "green stuff" but have not tried them yet. If you have not replaced your rotors PFYC has some pretty cool slotted rotors that will do a better job than stock staying cool under pressure.
TVW
Old Dec 1, 2004 | 11:13 AM
Juve's Avatar
Thanks
I have to do the front rotors in the next couple of weeks. The rears are new last week. Have a couple hundred miles before I hit 75k, so will do the fronts while I have it jacked up for the oil change. Will try some of the green stuff pads, but will keep the old ones in case I don't like em.
Old Dec 1, 2004 | 12:46 PM
montejass's Avatar
Default Green Stuff Pads
Cool.... Let us know what you think of these after a couple of hundred miles.
TVW
vita
Jul 14, 2013 08:29 PM
cbr600rrnut
Jun 2, 2010 11:53 AM
slinkeey
Jan 14, 2009 04:09 AM
thesheiladivine
Apr 15, 2008 12:24 PM
86monte818
Jul 16, 2006 05:37 AM
