04 monte carlo wont shift unless i reset the computer
Old Feb 20, 2013 | 09:32 AM
Capp10's Avatar
Default 04 monte carlo wont shift unless i reset the computer
Hi i have a 04 monte carlo ss. That i jus put a
New trans in. B4 i took the trans out of the other vehical
It shifted great no problems. Now that its in the monte
It shifted fine untill i turned the car off. Cranked it back up, an drove
It wouldnt shift out of 2nd. I disconnected the battery an trans
Harrnest to reset the computer an it shifts fine un till i
Turn the car off. Whats causing this
Old Feb 20, 2013 | 09:48 AM
What vehicle did you take the trans out of?
Old Feb 22, 2013 | 09:46 AM
Capp10's Avatar
04 grand prix
Old Feb 24, 2013 | 01:25 AM
Capp10's Avatar
Whats the reason for it not to shift
Old Feb 24, 2013 | 02:00 AM
Enzo354's Avatar
STILL SLOW
The 04 transmission is different. The gearing is different, that will mess with your shift points, which is what I am assuming to be the issue. I think you need to get it actually tuned for the change.
Old Feb 24, 2013 | 09:15 AM
Capp10's Avatar
Wn u say tuned u mean a tune up or pcm tune.
An would i get that done at a regular autoshop.
Or is it somthing i kan do myself
Old Feb 24, 2013 | 01:12 PM
Enzo354's Avatar
STILL SLOW
You will need someone with HPTuners or DHP tuners to do it. Honestly, ZZP might be able to help you out. See the issue is, the computer has set shift points, like 45 mph at 5500 rpm, etc. When you change the gear ratio, it can confuse the computer. I would assume that is your issue.
Old Feb 25, 2013 | 08:47 AM
Capp10's Avatar
Ok apprechiate da knowledge enzo. Learn sumthn
New everyday. Im try dat out. Ima keep u posted
flamz76
Sep 28, 2013 12:56 PM
litaf201
Aug 27, 2012 07:48 PM
SteveCZ28
Mar 13, 2012 03:04 PM
QUIZICAL MONTE CARLO
Jan 5, 2011 03:10 PM
fastback4
Jun 2, 2007 07:05 AM
