01 SS Motor Mount Replacement
Old Jul 27, 2009 | 03:51 PM
xman23's Avatar
Question 01 SS Motor Mount Replacement
Hi all,
First off I have lost overdrive in the tranny and plan to replace it in 2 weeks. Not sure if this is the cause of my issues. Secondly, I just looked at my motor mounts and they are severely cracked and the engine moves way too much when I shift.
ABS and Traction control warning lights stay on and car shakes violently under acceleration in right hand turns (fine in left turns) and when car is going straight and hitting dips in road. As soon as I let off the accelerator under both conditions, the shaking stops and the car drives smooth.
Could this be the effect of bad motor mounts?
I am going to go ahead and try the motor mounts since they look like they are going to fall off. Do I need an engine lift to accomplish this?
Thanks for any help
Old Jul 27, 2009 | 04:03 PM
Budsjlm's Avatar
well with the abs and tc lights on my vote is a bad wheel speed sensor the other stuff i wouldn't know...hope i helped some
Old Jul 27, 2009 | 05:13 PM
If it's just the dog-bones that you are replacing, you just unbolt one, put the new one, then unbolt the other, put the new on.
Old Jul 27, 2009 | 06:14 PM
MonteDriver's Avatar
sounds like the wheel hub to me not a motor mount. the engine mounts are easy to inspect for wear, just grab the motor and try and shake it if it moves a ton then its them and you should be abls to figure out the one thats fkd
Old Jul 27, 2009 | 06:58 PM
RED02SS's Avatar
The shaking sounds like a driver side wheel bearing going out. If it makes a roaring noise that would be my best guess for that. As far as the motor mounts, why not go ahead and replace them. It cant hurt anything. Just like chibiblacksheep said, one at a time.
Old Jul 28, 2009 | 08:33 AM
The wheel hub was my suggestion in another thread, so I didn't want to repeat myself :P
2003supersport
21
Apr 29, 2009 02:06 PM
2003supersport
Feb 4, 2009 09:15 AM
HyperFox
FWD Tech Guides '95-'07
14
Nov 7, 2008 12:18 AM
odessadude
Feb 2, 2008 07:23 PM
GooberMT
24
Sep 26, 2007 09:06 PM
