Finally got a clay bar for my Monte! Woohoo!
Old Nov 19, 2010 | 10:35 PM
  #31
jaws2008's Avatar
GOT SPL
Read the article in this thread about the claybar https://montecarloforum.com/forum/sh...ad.php?t=24358
A clay bar will NOT remove scratches. Find a rubbing compound and apply that. Follow with a wax after the compound, Or a polish than Wax.
Old Nov 19, 2010 | 11:10 PM
  #32
Ricks 2006 SS's Avatar
Possum: becare with Rubbing compound. Try the white stuff. POLISHING compound. Is a finer mix. Be careful not to go thru the clear coat. I've used that with good success. Then use a wax that won't dry white in the chips & scratches. Nothing I know will remove scratches. A scratche is where paint has been removed. Only way to fix that is Paint it.
Old Nov 19, 2010 | 11:52 PM
  #33
jaws2008's Avatar
GOT SPL
A polisher/buffer is the best way to remove scratches. Scratches can be removed if there not deep. Most scratches do not go all the way though the clear coat. I usually use M105 to compound out scratches followed by M205 then you can wax it. Ive worked on many cars most cars have tons of scratches around the key hole. Most are minor and are easily removed with a good compound such as M105 as I stated and follow With M205 and most if not all will be gone. If you cant remove a scratch completely but you sure can make them less visible. And if your working my hand you will never remove enough clear coat to make that an issue unless your sanding
ScratchX is a marketing gimmick and never works. It uses fillers as does Ultimate compound and SwirlX so the scratches and swirls will reaper over time.
Old Nov 20, 2010 | 05:33 PM
  #34
Mels SS's Avatar
Get yourself a good buffer like porter cable or Meguire's and a good polish Adam
or Surf City and practice on and old hood or trunk lid from the salvage yard.
Old Nov 20, 2010 | 07:43 PM
  #35
2001LSMONTE's Avatar
I agree
Old Nov 21, 2010 | 08:27 PM
  #36
Montelicious's Avatar
Been too cold to do it. Guess it will be done in spring, however please keep the tips and advice coming. I really appreciate it!
77gp
May 14, 2011 03:29 PM
thumpingetocar06
Jun 15, 2010 10:19 PM
jimbo7
Jun 5, 2010 11:55 AM
MonteLSV6
May 19, 2009 11:28 AM
montejass
Aug 13, 2005 05:51 AM
