Clay Bar & Clear Coat Sealant
Old Jul 31, 2005 | 04:09 PM
montejass's Avatar
Default Clay Bar & Clear Coat Sealant
I've spent the entire morning going over the entire car with a clay bar and finished it off with Wolfgangs Deep Gloss Paint Sealant and the results were amazing. I was shocked to see the amount of dirt residue the bar picked up and the sealant product made the paint feel like glass. The sealant was also super easy to remove and took very little to do the whole car.
Old Jul 31, 2005 | 05:35 PM
04MonteLS's Avatar
Default RE: Clay Bar & Clear Coat Sealant
ORIGINAL: montejass
[sm=ttiwwp.gif]
But yeah, that's the good thing about sealants. One thing I didn't hear you talk about though was polish and wax. Why did you skip those steps, especially after claying?
Old Jul 31, 2005 | 07:16 PM
montejass's Avatar
ORIGINAL: 04MonteLS
ORIGINAL: montejass
[sm=ttiwwp.gif]
I did skip those two steps as they were not suggested steps according to Wolfgang. Are the polish & wax required steps? What will happen if I only use the sealant?
Old Jul 31, 2005 | 07:41 PM
04MonteLS's Avatar
ORIGINAL: montejass
You absolutely should polish and wax before applying the sealant, especially after claying. Detailing is basically 3 steps, cleaning, polishing and protecting. By using the clay bar, you did the cleaning part. The next step should be to polish the paint which improves the texture of the paint by filling in any minor scratches and swirls which would surely be left behind due to the clay process. It also helps lay down a perfect foundation for the protection step by leaving behind a smooth, glossy surface. After polishing, the wax or sealant should be applied to protect and enhance the shine from the polishing you just did.
Going from clay to sealant is like applying a clear coat to a paint job w/o wet sanding the color coat first. You wouldn't do that would ya?
And Wolfgang does recommend the process as stated above, as noted here
Old Aug 2, 2005 | 01:14 PM
montejass's Avatar
I was not after optimal results... lol
I am pretty happy with the results, but I plan to wax it as you suggested next time I clay it. This weekend I have to try to clean up my wifes truck. I'll try it on that and let you know how things work out.
Old Aug 2, 2005 | 04:12 PM
04MonteLS's Avatar
ORIGINAL: montejass
No worries, just letting you know how it should be done. Where did you get the Wolfgang and how much did it cost you? I have heard nothing but good stuff about thier product.
Old Aug 2, 2005 | 04:29 PM
montejass's Avatar
I purchased it directly through the autogeek.com website through the many links on our forum. In all I think I paid around $30 for the clay bar and the sealant. I've never used anything like the sealant before and it's well worth a try.
Old Aug 2, 2005 | 05:12 PM
04MonteLS's Avatar
ORIGINAL: montejass
Sealants are nice, very easy to use and the results are remarkable. The thing I love about Wolfgang sealants, they are water soluable.
Old Aug 13, 2005 | 04:30 AM
03SSdriver's Avatar
When i got my 03 it was pretty clean. ( one reason i bought it).
The paint was very good, but after i clayed it, it was soooo smooth.
After polishing and waxing i can see the advantage of the clay system.
Very easy to do and definately worth the time.
Tj
Old Aug 13, 2005 | 05:51 AM
04MonteLS's Avatar
ORIGINAL: 03SSdriver
Tj
True story
JayBay
Sep 26, 2012 09:50 PM
NovaSS369
Aug 22, 2011 08:12 AM
irulesoha
Jun 11, 2011 09:29 AM
Cicatrix
Aug 2, 2010 10:50 PM
MonteLSV6
May 19, 2009 11:28 AM
