TPMS Whats The GM Part# ??
Old Mar 16, 2014 | 03:13 PM
Hiperguy's Avatar
Default TPMS Whats The GM Part# ??
Does anyone know the GM/Dorman/Schrader TPMS Part # for a 05 Monte with the 17" Wheels?? Any help would be greatly appericated.Thanks
Old Mar 16, 2014 | 04:32 PM
There is no TPM in the tires on 2005 Monte's they use Wheel Speed Sensor ..
Old Mar 16, 2014 | 06:20 PM
Hiperguy's Avatar
Default Wheel Speed Sencor
OK they have wheel speed sensors/ Tell me how to get the Check Tire Pressure light on the dash to go off?? The tires were low after setting for several months.Put the correct tire pressure in them and the stupid idiot light won't go off!!Someone said just drive it it will go off.Where are these Wheel speed sensors located and do theym go bad??
Old Mar 16, 2014 | 09:58 PM
Shelbo Mustang's Avatar
I know on a 2000 Monte which should be the same on most, you got to ...
1-turn the ignition from off to on three times (don't let the car start or you have to start all over)
then
2-pull your headlight switch all the way out three times
Hope this helps you. This should get rid of the light.
Old Mar 16, 2014 | 10:28 PM
If you have the factory radio you can also do the reset via the radio. If I recall, the sequence is get in the car, close the door, hold the display button (do not let go) and while holding the display button, turn the key to the accessory position. At that point give it 10-20 seconds, the radio should go into the various maintenance menus.
If I'm not correct, the procedure is in your owner's manual.
My experience with these cars is the computer calibrates the wheel speed sensor ratings, if they detect a change later on, it reports an issue (as you are seeing). It has no idea what the pressure is, just something changed and it's a problem. When you reset it, it re-calibrates (but the light will not go off until you reset it.
The wheel speed sensor is integrated into the wheel hub assembly.
Old Mar 17, 2014 | 07:56 AM
Car can be running. Just turn the radio off, then hold the DISP button until the menu pops up.
Then use the < and > to scroll through the main menus, and your 1 and 2 buttons to scroll through each sub menu.
DISP acts like an OK button.
Old Mar 17, 2014 | 12:08 PM
Hiperguy's Avatar
Default Wheel Speed Sensors/Tire Pressure Light Dash
OK they have wheel speed sensors/ Tell me how to get the Check Tire Pressure light on the dash to go off?? The tires were low after setting for several months.Put the correct tire pressure in them and the stupid idiot light won't go off!!Someone said just drive it it will go off.Where are these Wheel speed sensors located and do they go bad??
Old Mar 17, 2014 | 12:38 PM
c.stone.sihs52's Avatar
you can reset the low tire pressure through the sterio same as you would a change oil light just select reset warning messages.
jasonmcr
Jul 31, 2009 09:52 AM
bigmichaelcool
Dec 10, 2008 08:40 PM
snakeking194
Jul 7, 2008 03:54 PM
jasonmcr
Feb 29, 2008 06:28 PM
Chucks88SS
Dec 13, 2007 09:40 PM
