TPMS question
Old Apr 7, 2013 | 03:04 PM
iMuf's Avatar
Default TPMS question
Hey everyone so my 06' has tire pressure monitors and they seem to not be working properly. I'm probably going to get new ones but I was also running through the idea of if you can just disconnect the light some way and just not run with tire pressure monitors. Is there just a fuse that can be pulled or do you have to get in the dash and have the light pulled or is it possible to just "delete" the code and have the light turned off that way? again I am probably going to just get some new ones but I am running through all the options.
Old Apr 7, 2013 | 03:44 PM
I'm not sure if they are easy to delete, also most shops won't delete the codes for you because they are the law now.
Old Apr 8, 2013 | 06:17 AM
iMuf's Avatar
I got you, that makes sense. Well maybe you guys can help me out. Here is my issue, the other day I took a look at my front left wheel and it looked really low. so I went through my display and it was saying that it was at 30psi and my front left tire, which looked fine, was at like 21psi. So I physically checked my tires and it was pretty much the exact opposite of what my car was telling me. Which I thought was strange. Could it just be that they need reset, or is there even a way to reset them? or could it just be that I need to get new sensors? I don't want to spend money if I don't have to, that money could go towards my CAI lol. Thanks for any help guys
Old Apr 8, 2013 | 07:54 AM
Whenever the tires are rotated, you have to relearn the positions with the car.
The manual for the car should explain it to you. It's been a while since I had to do it for my Dad. You basically put the car into relearn mode using the buttons on the dash, then you have to either let air out of, or put air into the front left tire until the car honks. Then you move to the passenger front tire, then the passenger rear, then the driver's rear. Waiting for a honk before you move each time. Then the car learns the positions and then you can put the air in the tires back to 30-32 where you normally run them.
Old Apr 8, 2013 | 08:56 AM
iMuf's Avatar
Ohhhh, that makes sense haha. Thanks Chibi
Old Apr 8, 2013 | 09:11 AM
no problem
Facekicker
Oct 28, 2013 10:10 AM
77gp
Jan 26, 2012 06:50 PM
bigcat24
May 11, 2011 08:35 PM
jasonmcr
Jul 31, 2009 09:52 AM
Chucks88SS
Dec 13, 2007 09:40 PM
