TPMS question
Hey everyone so my 06' has tire pressure monitors and they seem to not be working properly. I'm probably going to get new ones but I was also running through the idea of if you can just disconnect the light some way and just not run with tire pressure monitors. Is there just a fuse that can be pulled or do you have to get in the dash and have the light pulled or is it possible to just "delete" the code and have the light turned off that way? again I am probably going to just get some new ones but I am running through all the options.
I'm not sure if they are easy to delete, also most shops won't delete the codes for you because they are the law now.
(Post 540591)
Whenever the tires are rotated, you have to relearn the positions with the car.
The manual for the car should explain it to you. It's been a while since I had to do it for my Dad. You basically put the car into relearn mode using the buttons on the dash, then you have to either let air out of, or put air into the front left tire until the car honks. Then you move to the passenger front tire, then the passenger rear, then the driver's rear. Waiting for a honk before you move each time. Then the car learns the positions and then you can put the air in the tires back to 30-32 where you normally run them. |
(Post 540809)
no problem :thumbsup:
