Torquing castle nut on ball joint
I've got an 02 Monte. I'm replacing the front passenger side axle. I noticed the castle nut on the ball joint gets 15 ft/lbs. Though, the axle is in the way, so you can't get a socket or ratchet onto the castle nut. I had to use an open ended wrench to loosen the castle nut.
How do you torque the castle nut on the ball joint with the axle in the way?
6th Gen ('00-'05): Ball joint or tie rod end?
John1980
Apr 30, 2015 08:01 AM
