service traction, grinding on take off.. abs when braking
Old Jul 24, 2013 | 04:24 AM
NYGiantsfan's Avatar
Default service traction, grinding on take off.. abs when braking
hello so pretty much most of the time when i begin to drive i feel a wining type noise as if the traction is "working" or slipping, and then sometimes the lights come on abs and traction off and service traction..
i replaced both front hub bearings recently and this is still going on..
i dont have the emergency brake working could that someway trigger the abs to keep kicking on or something..also i noticed the pass side axle is leaking and hear a light pop type of noise when i take off from the driver side..noticed some very light vibration from brake pedal and sometimes when i brake i notice the abs kicking in for no reason..for some odd reason i feel these issues are intertwined idno
any help would be great
thanks in advance
running out of ideas
Old Jul 24, 2013 | 08:09 AM
Get the ABS code read. Even if the rear hub assemblies fail this could happen.
You could have replaced the fronts for no reason
Old Jul 24, 2013 | 12:13 PM
Cowboy6622's Avatar
When you rpelaced the front hubs, did you be careful to feed that ABS wire through the slot carefully? might have ti pinched off and the wire grounding out on the metal, causing you problems....
mwmarshall
May 14, 2022 02:43 AM
teamfbody
34
Aug 11, 2013 08:22 PM
Chris s
Jan 27, 2013 04:30 PM
American_Muscle
Oct 19, 2011 01:23 AM
