Replaced rotors, pads and hub assembly now squealing is real bad
Is the sound constant? Is it possible that you have a bad drive axle? If you step on the brakes does it get worse? I would take the wheels off and check everything again. Make sure the pads are seated correctly and straight in the bracket. Good luck
Kind of. The hub assembly on the driver side kept losing the top bolt. That cause the squealing on that side but ruined my rotors and cv joint. The one on the passenger sides still squeals. Only thing i haven't replaced on that side is the CV. But i don't think its that. I think the 2 hub assemblies i got from rock auto were defective and i essentially swapped one squeal for an identical one because that is why i replaced them in the first place. I bought CV joint for the passenger side just to make sure so when i get that installed it'll have to be the hub assembly. I suppose.
matthew41
01-25-2015 11:22 AM
6th Gen ('00-'05): Funny Story.... So I recently replaced my Pads and Rotors
Henderson21
07-09-2014 04:28 AM
phoenix_iii
03-22-2006 11:00 AM
