Rear-Heightening-Springs???
has anyone used these?
does anyone have a pic?
my rear end sags and i want to help the stance. im scarred to go lowered because i feel i will have the same problem, just an inch lower. dont get me wrong i like the reduced gap. does that happen???
i like the idea of the hieghtening springs over spacers. just kinda wodering if they make the car hight stock, with extra weight in the trunk. im sure they help transfer weight to the front end too.
well what you could do is just replace your springs with a higher compression weight/spring rate/ i'm not exactly sure what it's call... that would help compisate for the extra weight from your subs
well i was planning on buying an fe4 set, mounts, springs struts, with 11 thousand mies on them for 99 bucks from morads. then i posted a tread about them and 3 days later they were gone. lol
so im going a different route
i heard that lowereing springs have a stiffer spring rate and take off like 50 lbs. thats still not enough.
i was going to say i think lowering springs have a better spring rate what about springs from another car maybe? idk hard to say since your seventh gen hasn't had the trial and errors like my 4th
