Low Tire Pressure Light
Old Apr 15, 2008 | 11:17 AM
MotorTSki's Avatar
Default Low Tire Pressure Light
Blew a tire, got it changed out. No prob. I have an aftermarket head unit and I really want to avoid putting the stock one back in to reset the "Low Tire Pressure" light. I know that you can reset the "change oil soon" light without the original head unit by pumping the gas pedal. Any similar way to reset the tire sensor? Will unplugging the battery clear it out? Or am I stuck swaping out the radio?
Old Apr 19, 2008 | 10:17 PM
RocknSS04's Avatar
Default RE: Low Tire Pressure Light
Turn the key to the on position, click your heels together three times, and say "there's no place like home"
Seriously now, from the DIY section here is the following thread:
https://montecarloforum.com/m_68070/..._/tm.htm#68242
It says with the key on, pull and push the light switch to the parking light (1st click) 3x, then turn the key off, to reset the tire pressure monitor, which BTW, is run by the speed sensors in the wheel hubs.
Old Apr 20, 2008 | 11:25 PM
MotorTSki's Avatar
Thanks everything worked out great.
Justin
Sep 4, 2010 11:24 PM
widebody
Aug 5, 2010 05:25 AM
Ulsterman
Aug 12, 2008 02:13 PM
chevyrider08
Apr 29, 2008 10:04 PM
amberblk00
Sep 12, 2007 03:03 PM
