4th Gen ('81-'88): Drag raidals
Old Mar 21, 2014 | 12:20 AM
jenningsm5.7's Avatar
Default Drag raidals
Hey guys,
Looking to get some advice for drag radials, I have the stock ss rims from my 87 Monte , and I wanted to know if anyone know the widest size you can fit on them... or a set if you could name a set drag radials that you guys run Im pretty set on sticking with the stock rim I like the look and if its possible I want to keep it for the track to. If anything I am also debating getting Iroc Z rims which I've read are a inch wider... any thoughts ?? Please Let me know what you guys think !
Thanks
Old Mar 21, 2014 | 02:32 AM
rumpfox's Avatar
your stock rims are 7"wide so could puta 9" slick on it. you can go 2"s wider than your wheel is arule of thumb or slick will just contact on the wheel bead spots. i have a 86 and see that you drag race yours. any performance mods. the talk is that if you apply serious power to the ground the rear is going to brake. i just put a 420 hp 355 in mine now they say i'm going to have to upgrade the rear.
Old Mar 21, 2014 | 07:40 AM
03SSLE's Avatar
Either that or snapping u-joints (they usually go first). Once you decide to lay some power down it becomes a perpetual process of replacing the weak parts in the link until you have consistent performance with minimal breakage. At this point installing driveline safety loops may be a good idea. Like I said, the u-joints will usually snap before the rear end goes. If the front u-joint snaps it can catapult your car - been there, done that...but no t-shirt awarded.
Old Mar 22, 2014 | 08:48 PM
rumpfox's Avatar
oh i've learned you put solid u-joints in for a 4 wheel drive no grease fittings solid cross, and 86 montes has a front strap factory
The_Maniac
Aug 8, 2013 11:15 PM
BeachBumMike
Jun 30, 2007 10:50 PM
The Black Machine 29
Jun 20, 2006 01:00 AM
86monte818
Jun 8, 2006 09:50 AM
Boost
Oct 20, 2004 10:53 AM
