Vogtland Lowering Springs
Old Jan 28, 2014 | 10:27 PM
Crusader SS's Avatar
Talking Vogtland Lowering Springs
Good evening everyone.... My wait is almost over... My Vogtland lowering springs have arrived...... They will lower her 1.2" in the rear and 1.26" in the front... Also, just received my anti-pogo washers from ZZP... I ordered 4 and received 2 red powder coated... My question is that missing 2 can I just put them in the front?...... I have read that is all you need, is this true?...... Any help would be appreciated... Thanks,
Old Jan 29, 2014 | 12:41 AM
ohara's Avatar
Sorry I can't help with your questions as I've never lowered a car so I have no knowledge on the subject.
But......I am very interested to see how your car looks when you get them installed
Please post some before and after pics if you can, as I've pondered the idea on lowering my car, only problem is that I don't know if I could get out of the car once I got in
Old Jan 29, 2014 | 09:33 AM
Hiroska's Avatar
Yeah post pics homie ^_^ ;
Old Jan 29, 2014 | 06:19 PM
I definately will...
Old Jan 29, 2014 | 08:20 PM
xxtheshockerxx's Avatar
RED DEVIL
What kind of struts are you going to run? I look forward to seeing the end result
Old Jan 29, 2014 | 09:24 PM
I've now had two Monte Carlos lowered and I have NOT installed anti-pogo washers OR camber bolts in both cases and have been 100% okay. The fronts are more likely to walk around, or "pogo", than the rears but honestly I've never had an issue with that.
Looking forward to seeing some pictures.
Old Jan 29, 2014 | 10:04 PM
I had the struts done last August (nothing special just Monroe Sensa-trac)... My rear is sagging a bit, so I can't wait to see the final result...
Old Jan 29, 2014 | 10:13 PM
Thanks that's exactly what I was hoping for
Will definately have pics...
Old Jan 29, 2014 | 10:17 PM
One more question, did you have to install shorter dog bones... Really appreciate your help...... Thanks
Old Jan 29, 2014 | 10:21 PM
Nope, didn't need to do that either. Just make sure you get an alignment after everything is reinstalled.
